OpenCL: What's best practice for replicating a task kernel in-FPGA?
Well, things have gotten weirder.
The error I posted above is coming from legacy emulation on my local compute server using aoc 20.1.
We don't have fast emulation working yet on our local server.
On the dev cloud, where can use fast emulation, I'm uniformly getting a seg fault, as I described above. In addition, I noticed today that one of my kernels reports a compute ID of -1 a few print statements before the seg fault.
However, also on the dev cloud, if I use legacy emulation with num_compute_units=1, it works. My program runs and declares PASS on valid answers.
If I run on the dev cloud with num_compute_units=2, legacy emulation mostly works, but it hangs without completing. Fast emulation seg faults as before.
So anyhow. I'm going to hunt for more clues.
I am not sure if this is an artifact in your snippet but it seems you are reading from and writing to channels with the same ID as the compute unit (albeit with different channel names). One would typically read from a previous compute unit and write to a following one, you should not read from and write to the same channel ID in the same compute unit. Another potential pitfall is channel ordering; the compiler will freely re-order channel operations and if there is a cycle of channels in your design, you can potentially run into a dead-lock unless you enforce channel re-ordering using barriers as described in Intel's documentation. Finally, it seems v20.1 is quite problematic based on reports from you and other people in the forum, you might want to consider switching to v19.4 on your local machine and see if you would run into the same problems. Assuming that you can create a minimal example that reproduces the issue and post it here, it will be easier to find potential issues in the code.
