Manual simulation of a HLS design failed
- 5 years ago
I'm replying to my own topic for resolving the issue. The problem was the .do file that is generated when executing NativeLink testbench from Quartus marks the source files generated by HLS Compiler as Verilog 2001 instead of SystemVerilog. Perhaps because the files are with the .v extension instead of .sv, even though they contain SystemVerilog specific code?
Replacing all of the -vlog01compat with -sv option in the .do file (and then running the .do file again in ModelSim) allowed the execution of the test bench.E.g.:
vlog -sv -work work +incdir+C:/../dsp_hls_streams.prj/quartus {C:/../dsp_hls_streams.prj/quartus/quartus_compile.sv} vlog -vlog01compat -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_arb_intf.v} vlog -vlog01compat -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_avm_to_ic.v}
Replace with -sv:vlog -sv -work work +incdir+C:/../dsp_hls_streams.prj/quartus {C:/../dsp_hls_streams.prj/quartus/quartus_compile.sv} vlog -sv -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_arb_intf.v} vlog -sv -work dsp_hls +incdir+c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules {c:/../dsp_hls_streams.prj/quartus/db/ip/dsp_hls/submodules/acl_avm_to_ic.v}
E.g.:
Replace with -sv:
Glad your problem is solved and thank you for sharing your solution. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
