Vishvas's avatar
Vishvas
6 years ago
Kernel execution time
In my program the execution time of the kernel is more than the execution time of the entire program
In the output screen (Attached Screenshot) 'Execution time of kernel' is measured using 'clGetEventProfilingInfo'
and 'Execution time' is measured using clock_t, similar to this link and it measures the total time taken by the main function
This issue occurs only when I run my code on DevCloud, if I run it on my PC then Execution time > Kernel Execution time
Why is this happening?
int main()
	start = clock();
	err = clEnqueueNDRangeKernel(queue, multiply_ker, 1, NULL, &global, &local, 0, NULL, &event);
	clWaitForEvents(1, &event);
	clFinish(queue);
	end = clock();
  • Hi Vishvas,
    Thanks for reaching out us.
    Could you please let us know the node in which you are running the application, Is it in FPGA nodes of Devcloud?
    Chithra
    • Vishvas's avatar
      Vishvas
      The node is : s001-n139
      And Device is Arria 10 Platform as shown in the screenshot
      I compiled the OpenCL code into RTL and ran it on FPGA.
      The issue I mentioned only occurs on FPGA, if I simulate it on CPU the timings are proper
  • Hi Vishvas,
    Thanks for the information. Since your issue is related to FPGA, we are moving this query to FPGA forum for a faster response.
    Chithra
  • AnilErinch_A_Intel's avatar
    AnilErinch_A_Intel
    Hi ,
    Please let us know whether the issue is resolved using clock_gettime. If not we can look in to further possibilities.
    Thanks and Regards
    Anil
    • Vishvas's avatar
      Vishvas
      I had some issues implementing it, but I was able to complete it now
      Thanks a lot for your help!
