Ric2
2 years agoInter-Kernel and Kernel-Host Pipes in one design
Hi, we are transfering a HLS IP core design to the new sycl HLS tool flow. During this migration several issues came up. We have one of them isolated here and generated a reproducer (please see attac...
- 2 years ago
This issue was successfully reproduced.
You can use the sycl::ext::intel::experimental::pipe as an inter-kernel pipe or as a host pipe. I was able to get your code to compile by changing ProducerToConsumerPipe as so:
using ProducerToConsumerPipe = ext::intel::experimental::pipe< // Defined in the SYCL headers.
class ProducerConsumerPipeId, // An identifier for the pipe.
INTRA_KERNEL_TYPE, // The type of data in the pipe.
4>; // The capacity of the pipe.It's odd that you can't have a mixture of experimental pipes and non-experimental pipes; we've opened a bug report internally on this. Thanks for reporting!
BoonBengT_Altera
Moderator
2 years agoHi @Ric2,
Thank you for posting in Intel community forum and hope all is well.
Noted on the attached example, please do allow us some time to compile the mention example and will get back with you on updates or clarification.
Appreciate the patients.
Best Wishes
BB
