Intel FPGA AI suite accuracy drop
One thing to check is your channel order. By default dla_benchmark will feed input data as RGB, but the dla_benchmark option `-bgr` will reverse the channels. This could be the culprit for a performance drop of this scale.
Hello @AndrewRooney,
Thank you for your help but that's not the problem. The same NN was compiled to be run only in the ARM CPU by only changing the
--fplugin flag to --fplugin "HETERO:CPU" and it worked. So the same NN result in a 74.64% acc in HETERO:FPGA,CPU mode and the wcuracy goes to 98% with HETERO:,CPU.
After performing some tests, we found the problem was related to the fully connected layers. The input shape of the FullyConnected layer, due to some design constrains, was [1, 1, 512] without a flatten layer. If a flatten layer is included before the FC layer, the inference turns to be right. So the problem was related with the FC layer and the HETERO:FPGA:CPU compilation.
