Wei-Chih's avatar
Wei-Chih
3 years ago
how to change h.parallel_for(range(M, P), [=](auto index) to single_task function
Hi support team I modified the code from opeapi samples mul, and I wanna use it for FPGA hardware. I am not sure how to modified these three parallel_for function to single_task. May you give me s...
  • aikeu's avatar
    3 years ago
    Hi Wei-Chih,
    Sorry for late reply.
    I may not understand the written code that you are trying to work with.
    Can you provide more decription on the operation that you are trying to work on?
    I think you can split your task using a normal for loop as compared to using parallel_for:
    Brief example as below:
    // Computes the product of two square matrices.
    void matrix_multiply(double** m1, double** m2, double** result, size_t size)
    for (size_t i = 0; i < size; i++)
    for (size_t j = 0; j < size; j++)
    double temp = 0;
    for (int k = 0; k < size; k++)
    temp += m1[i][k] * m2[k][j];
    result[i][j] = temp;
    // Computes the product of two square matrices in parallel.
    void parallel_matrix_multiply(double** m1, double** m2, double** result, size_t size)
    parallel_for (size_t(0), size, [&](size_t i)
    double temp = 0;
    There is this document that might help to consider how your code will be written:
    https://www.colfax-intl.com/downloads/oneAPI_module04_DPCplusplusFundamentals2of2.pdf
    Aik Eu
