Failure to fit an Arria 10 design through insufficent LABs when no problem in reports
- 5 years ago
Hi
With insight from an Intel FPGA expert I have now solved this issue. The problem is that the reports are misreporting the percentage of MLABs that the design is using. The compiler error message is correctly indicating that I am asking for too many MLABs whereas the corresponding Area Analysis report is saying I am using only 65% of them.
My solution is to check my MLAB use against the known MLAB capacity of the FPGA rather than trust the report.
Marcus
Hi
Marcus
