jland's avatar
jland
4 years ago
CL_INVALID_BINARY error trying to run on arria10 FPGA (Intel Devcloud)
I believe this issue is a somewhere between High Level Design and the Intel Devcloud environment. If this post is better suited to be asked elsewhere, feel free to let me know.
Below is the error I am a bit stuck on:
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
Aborted
I have been using the "Hough_Transform_on_FPGAs_Using_oneAPI" jupyter notebook collection as a reference for this process. From what I have read, this error seems to usually be related to trying to run an FPGA bitstream on the wrong type of device. I am fairly certain everything I have done should be aimed an an arria10 device, though I could be wrong. Everything appears to work fine on an emulator or a normal program compilation. I only run into trouble running on the actual FPGA hardware.
This is the command I have been submitting to an fpga_compile node. My understanding is that this should default to be arria10 compatible.
dpcpp -v -fintelfpga -Xshardware main.cpp -o pseudo.fpga
I have tried running this on different fpga_runtime / fpga_runtime:arria10 nodes with no success. Below I am including the section of my code where the error is occurring incase it is helpful, but I do not believe it is currently the cause of my issue. (I might be very wrong though!)
device_queue.submit([&greyscale_buffer, &image_buffer, image, width, height, out](cl::sycl::handler& cgh) {
    // A discard_write is a write access that doesn't need to preserve existing memory contents
    auto data = greyscale_buffer.get_access<cl::sycl::access::mode::discard_write>(cgh);
    auto image_data = image_buffer.get_access<cl::sycl::access::mode::read>(cgh);
    // THIS PARALLEL_FOR IS WHERE THE ERROR OCCURS
    cgh.parallel_for(cl::sycl::range<1>(width * height), [image_data, out](cl::sycl::id<1> idx) {
        //     Just commented out code inside currently
}).wait();
If there's anyone who could help point me in the right direction it would be much appreciated. Thanks!
  • jland's avatar
    jland
    Unfortunately this does not seem to resolve the issue. I see this documentation states, "the compiler chooses the default FPGA board variant pac_a10 from the intel_a10gx_pac BSP". I connected to an fpga_runtime:arria10 node and ran the following command:
    > aocl initialize acl0 pac_a10
    aocl initialize: Running initialize from /glob/development-tools/versions/oneapi/2022.2/oneapi/intelfpgadpcpp/2022.1.0/board/intel_a10gx_pac/linux64/libexec
    Program succeed.
    After doing this, I still run into the same error trying to run the program on an FPGA. I also tried initializing pac_a10_usm which fails, but since it is not the default board variant I don't believe it is a factor here.
  • hareesh's avatar
    hareesh
    can you pls share what steps you are following for initialization and compilation
    • jland's avatar
      jland
      I've been using the "Hough_Transform_on_FPGAs_Using_oneAPI" jupyter notebook as a guide for the process. Not too sure on how to share it since it was just included in my user folder. The specific notebook I am referencing should be located at "~/Hough_Transform_on_FPGAs_Using_oneAPI/03_FPGA_Bitstream_Compilation_Using_the_Intel_FPGA_Add-On_for_oneAPI_Base_Toolkit/FPGA_Bitstream_Compilation_Using_the_Intel_FPGA_Add-On_for_oneAPI_Base_Toolkit.ipynb".
      I think have shared the steps I am doing for compilation and the nodes I have been trying to run on above. If there's some piece which seems missing feel free to let me know.
  • hareesh's avatar
    hareesh
    When are you getting problem at initialization or compilation time?
  • hareesh's avatar
    hareesh
    we don't received any response from you. can you pls respond?
  • hareesh's avatar
    hareesh
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    Thank you.
