Can not compile the examples on Quartus Prime.
- Regarding device family. Supported device families are:Cyclone 10 GX, Stratix 10, Arria 10, MAX 10, Cyclone V, Arria V, Stratix V.
- To which device PN you have generated the HLS IP/Design? default is Arria10 if we use build.bat file.
Refer session 8.1 from below link for Adding the HLS Compiler-Generated IP into an Intel Quartus Prime Project.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf
I have used Quartus lite 18.1 & MS Visual Studio 2010 on windows 10 environment.
example design of counter with Cyclone V device and followed session 8.1 from above link.
Anand
- ukhuc7 years ago
Dear Anand,
Thank you for your helpful answer.
in my situation, refer session 7 was more useful than 8.1 from https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf.
You were right. My test-fpga.exe (test-fpga.prj) was created on Arria10. but I was trying to compile it on Cyclone IVE device family on QPLite. After your answer, i tried on CycloneV device and it compiled successfully. Thank you again.
