ldm_as's avatar
ldm_as
7 years ago
Async Resets for Flops -> what polarity is preferable?
Hi All,
As for the Async Reset for the flops - what polarity is preferable (posedge or negadge)?
If I don't define a default value for FF, will it be '0'?
Thank you!
1 Reply
  • KennyT_altera's avatar
    KennyT_altera
    Usually would be negedge
    always @ (negedge <reset> or posedge <clock_signal>)
    begin
    // Reset whenever the reset signal goes low, regardless of the clock
    if (!<reset>)
    begin
    <register_variable> <= 1'b0;
    end
    // If not resetting, update the register output on the clock's rising edge
    else
    begin
    <register_variable> <= <data>;
    end
    end
    You can right click the vhdl -> insert template -> verilog hdl-> logic -> register
    Look into the details.
    You can also look into https://www.intel.co.jp/content/dam/www/programmable/us/en/pdfs/literature/quartus2/qts_qii51006.pdf page 9-4
    If you don't defined, there will be no reset port in your flop flop.
