Apologies for the confusion. I've been trying to build the slim 1x16 PCIe using the following command:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
But I've been running into a couple crashes and compilation issues after some time passes, notably an error stating: "Error: UNAVAILABLE: Network closed for unknown reason." This error has appeared several times at the same point in compilation, despite constant connection to my network via Ethernet cable. As such, I don't think it's a connectivity issue. Another user ran into this issue when compiling for an F-Series board (link), and their issue was resolved by upgrading system RAM to 96GB, so I am looking into possibly doing that as well.
My current system uses an i7-12700K and 64GB of DDR4 RAM. If you have any other insight or advice, please let me know as I continue to troubleshoot this new issue for the 1x16 PCIe configuration! The complete compilation log is attached for reference. I'll keep you posted if anything advances on my end.
Thank you!
James
Can you try to implement the workaround in Why do I unexpectedly observe intermittent DDM Errors? | Altera Community - 349714?
