Blog Post
Blog
2 MIN READ
Channel Estimation with AI on Altera SoC FPGA
ChristianLanzani's avatar
ChristianLanzani
1 year ago
Boosting Wireless Intelligence: AI-Accelerated Channel Estimation with FPGAi
As wireless systems evolve to support more connected devices and higher data demands, the efficiency and precision of the radio signal chain become critical. One of the most foundational elements of this signal chain is channel estimation—the process by which a system infers the characteristics of the wireless communication path in real time. Inaccurate estimation can degrade throughput, introduce latency, and reduce system reliability.
Traditional techniques such as Least Squares (LS) and Minimum Mean Square Error (MMSE) have served the industry for years, but they begin to falter in low Signal-to-Noise Ratio (SNR) environments or under high-mobility conditions. As network complexity increases, so does the need for smarter, adaptive algorithms.
Bringing AI into the Signal Chain
Altera is pushing the boundaries of what’s possible with AI-based channel estimation deployed on Agilex™ SoC FPGAs using the FPGA AI Suite. By integrating Convolutional Neural Networks (CNNs) into the channel estimation process, engineers can achieve dramatically better performance compared to legacy methods—especially in challenging conditions.
In our demo, we used MATLAB for initial signal processing experiments and then deployed the trained CNN models onto the FPGA using our toolchain. The results are striking:
  • ~20% higher throughput in the -10 dB to 0 dB SNR range compared to MMSE
  • Matched or exceeded performance at higher SNRs
  • Reduced latency and resource usage with efficient hardware mapping
These gains are not just theoretical—they translate into better user experience, more robust network behavior, and improved spectral efficiency across the board.
Why This Matters for the Future of RAN
Modern RAN systems—particularly in mMIMO and Open RAN architectures—require real-time responsiveness and the ability to adapt to channel variations with minimal overhead. FPGAi enables this by combining the parallelism and flexibility of programmable logic with trained AI models that excel in recognizing complex patterns.
With Agilex SoC FPGAs, designers can integrate AI-driven estimation seamlessly into the PHY layer, eliminating the need for off-chip accelerators or cumbersome post-processing.
Smarter Estimation, Smarter Networks
Channel estimation is just one part of the wireless pipeline that can benefit from AI-native architecture. As part of our broader effort to Redefine Radio Access Networks with FPGAi, this solution shows how combining domain-specific AI with programmable logic can deliver immediate and measurable improvements in performance, flexibility, and efficiency.
To learn more or to watch the full demo, head to our Youtube, explore our Wireless Solutions page or connect with our technical team to begin building your next-gen wireless system with FPGAi.
Published 1 year ago
Version 1.0
