Knowledge Base Article
Why rx_pcs_fully_aligned signal keep toggling in the GTS PMA/FEC Direct PHY IP when configured to the PCS Direct mode (IEEE MII Interface)?
Description
The rx_pcs_fully_aligned signal keeps toggling in the GTS PMA/FEC Direct PHY IP when configured to the PCS Direct mode (IEEE MII Interface) due to the one-bit shift in PCS data mapping for 80-bit data.
Resolution
To work around this problem, follow the table below for data bit mapping if using GTS PMA/FEC Direct PHY IP in PCS Direct mode (IEEE MII Interface).
MSB
LSB
TX Parallel Data
RX Parallel Data
75
i_tx_mii_c[7]
o_rx_mii_c[7]
74
67
i_tx_mii_d[63:56]
o_rx_mii_d[63:56]
66
i_tx_mii_c[6]
o_rx_mii_c[6]
65
58
i_tx_mii_d[55:48]
o_rx_mii_d[55:48]
57
i_tx_mii_c[5]
o_rx_mii_c[5]
56
49
i_tx_mii_d[47:40]
o_rx_mii_d[47:40]
48
i_tx_mii_c[4]
o_rx_mii_c[4]
47
40
i_tx_mii_d[39:32]
o_rx_mii_d[39:32]
38
i_tx_mii_valid
o_rx_mii_valid
37
i_tx_mii_am (RSFEC)
Reserved(Firecode FEC)
o_rx_mii_am (RSFEC)
Reserved (Firecode FEC)
35
i_tx_mii_c[3]
o_rx_mii_c[3]
34
27
i_tx_mii_d[31:24]
o_rx_mii_d[31:24]
26
i_tx_mii_c[2]
o_rx_mii_c[2]
25
18
i_tx_mii_d[23:16]
o_rx_mii_d[23:16]
17
i_tx_mii_c[1]
o_rx_mii_c[1]
16
9
i_tx_mii_d[15:8]
o_rx_mii_d[15:8]
8
i_tx_mii_c[0]
o_rx_mii_c[0]
7
0
i_tx_mii_d[7:0]
o_rx_mii_d[7:0]
Also, bit 76, which was captured as o_tx_mii_ready in previous versions of the GTS PMA/FEC Direct PHY IP user guide, is obsolete. It is not recommended to use this bit. This will not impact the functionality.
Updated 1 month ago
Version 2.0
