Knowledge Base Article
Why isn't the chainout adder used by my inferred DSP?
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, you may see an adder implemented in registers rather than being absorbed into a DSP block. This occurs when the tool detects a loop going through the DSP block and adder.
Resolution
To work around this problem, set a keep attribute on the signal looping from the DSP output to it\'s input. This prevents the loop from being detected.
Verilog HDL example
wire feedback_wire /*synthesis keep*/
VHDL example
signal feedback_wire : std_logic;
attribute keep: boolean;
attribute keep of feedback_wire: signal is true;
Updated 20 days ago
Version 2.0
