Knowledge Base Article
Why is the Output Enable behavior for BLVDS outputs inverted in Arria V devices?
Description
Due to a problem with the Quartus® II software version 12.0 and earlier, a BLVDS output made up of two single ended ALTIOBUF megafunctions and the pseudo diff out atom will have inverted OE behaviour when implemented in Arria® V devices.
This problem does not affect either RTL or post-fit simulation models.
Resolution
Instead of instantiating the pseudo diff out atom and single ended buffers, the differential output buffer should be instantiated by creating a differential output with OE variation of the ALTIOBUF megafunction.
This problem is fixed in the Quartus II software version 12.0SP1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
