Knowledge Base Article
Why is the functionality of my VHDL-2008 conditional signal assignment incorrect?
Description
Due to a problem in the Quartus® Prime Pro Edition Software, you might see that the following code is not implemented correctly.
example_process : process (clk)
begin
if rising_edge(clk) then
signal_1 <= input_a;
signal_1 <= input_b when select_signal;
end if;
end process example_process;
This should create a registered mux but instead creates a register with input_b connected to D input and select_signal used as the enable.
This code is only valid in VHDL-2008.
Resolution
To work around this problem, use this code instead.
begin
signal_1 <= input_b when select_signal else input_a;
end if;
Updated 2 months ago
