Knowledge Base Article
Why is my ramstyle attribute included in the Ignored Source Level Assignments report?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 18.1 and earlier, you may see the HDL coded ramstyle attribute reported  in the synthesis report, Processing > Compilation Report > Synthesis > Source Assignments > Ignored Source Level Assignment.
This happens when you have ramstyle attribute being written in Verilog HDL or VHDL code for your design as below.
Verilog: (* ramstyle = "M20K" *) reg [<msb>:<lsb>] <variable_name>[<msb>:<lsb>];
VHDL: attribute ramstyle : string;
attribute ramstyle of <object> : <object_class> is <string_value>;
Resolution
It is safe to Ignore the report for "Ignored Source Level Assignments" for "ramstyle". RAM will still be implemented correctly in Fitter. It is shown in fitter report under Fitter -> Place Stage -> RAM Summary report.
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 21.1.
Updated 11 months ago
Version 3.0
