Knowledge Base Article
Why is incorrect data rate set in the Serial Lite IV IP when generating F-Tile Serial Lite IV Intel® FPGA IP on Windows?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1 and earlier, you might see an incorrect data rate is set in the Serial Lite IV IP when generating F-Tile Serial Lite IV Intel® FPGA IP on Windows.
You can check it with the 'EHIP_DATA_RATE' parameter in the following generated files:
- <ip_name>\sl4_f_500\synth\hip\sl4_hip_<ip_name>_sl4_f_500_***.sv
- <ip_name>\sl4_f_500\synth\hip\ sl4_hip_bb_<ip_name>_sl4_f_500_***.sv
This may cause a Support-Logic Generation error when compiling design including F-Tile Serial Lite IV Intel FPGA IP.
This problem doesn't happen on Linux.
Resolution
A patch is available to fix this problem for the Intel Quartus Prime Pro Edition Software version 22.1. Download and install Patch 0.19 from the following links:
- Patch 0.19 for Windows (quartus-22.1-0.19-windows.exe)
- Readme for patch 0.19 (quartus-22.1-0.19-readme.txt)
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 8 months ago
Version 4.0No CommentsBe the first to comment
