Knowledge Base Article
Why is Altera® USB Blaster not detected by Quartus® Programmer when it is recognized correctly in Device Manager?
Description
The version of JTAGServer running as a host is not working properly as a user mode application.
Resolution
To resolve this problem, use the following steps:
1.       Run Windows in SAFE MODE
2.       Run “msconfig” in command prompt to bring up System Configuration Window
3.       In Service tab, disable “Altera JTAG Server” and then reboot the PC.
Updated 3 months ago
Version 2.0
