Knowledge Base Article
Why is a reconfig_mif file not generated during compilation of my design containing a bonded mode transceiver instance for Stratix V or Arria V devices?
Description
Due to a problem in the Quartus® II software versions 12.0 service pack 2 and earlier a reconfig_mif file will not be generated for any Stratix® V or Arria® V transceiver instances if your design contains any transceiver instances in a bonded mode.
Resolution
To workaround this issue either remove the bonded instantiations from your design or create a test design containing only the non-bonded instances.
This problem is scheduled to be fixed in a future version of the Quartus® II software.
Updated 3 months ago
Version 2.0
