Knowledge Base Article
Why does the Quartus® II software freeze when I add a signal to the SignalTap II Logic Analyzer?
Description
Due to a problem in the Quartus® II software version 12.0 SP2 and earlier, the Quartus II GUI may freeze when adding signals in the SignalTap™ II Logic Analyzer if your quartus2.qreg file contains an invalid statement.Resolution
To work around this problem, open quartus2.qreg and remove any lines that contain the text "Node_finder". The quartus2.qreg file can be found in the following location:
- Windows 7: C:\users\<username>
- Windows XP: C:\Documents and Settings\<username>
- Linux: ~/.altera.quartus
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 2 months ago
