Knowledge Base Article
Why does the Intel® Quartus® Prime Pro Edition Software version 22.3 quit unexpectedly when using RHEL 8.6 OS?
Description
Due to a problem in the  Intel® Quartus® Prime Pro Edition Software version 23.1 and earlier, you might see a fatal error when the environment variable LD_LIBRARY_PATH is set.
The stack trace will show the following messages:
, {   "address": 139827833211164
,   "build_id_offset": 1030428
,   "function_name": "QGuiApplicationPrivate::createPlatformIntegration()"
,   "file_name": "/opt/tools/intel/FPGA_pro/22.4/quartus/linux64/libQt5Gui.so.5"
Resolution
To work around this problem, unset the LD_LIBRARY_PATH variable for the Intel® Quartus® Prime Pro Edition Software.
For example, in Linux, to modify the environment before running a program, use the 'env' command:
$ env --unset LD_LIBRAY_PATH quartus
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 23.2
Updated 2 months ago
Version 2.0
