Knowledge Base Article
Why does the In-System Memory Content Editor display incorrect Instance ID?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1 and earlier, you might see the Instance ID is displayed incorrectly as default "NONE" in the In-System Memory Content Editor (ISMCE).
Resolution
To work around this problem, follow these steps:
1. Go to <Quartus_installed_directory>\ip\altera\sld\jtag\intel_mce\intel_mce_hw.tcl
2. At line 111, change NODE_NAME type from NATURAL to STRING as the following:  add_parameter NODE_NAME STRING 0
3. Regenerate HDL of related IP, recompile and reprogram the .sof file
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 23.2.
Updated 11 months ago
Version 3.0
