Knowledge Base Article
Why does the GTS AXI Streaming IP for PCI Express* design example for Agilex™ 5 FPGAs fail to operate and enumerate in hardware when loaded from QSPI on the Agilex™ 5 FPGA E-Series 065B Modular Development Kit (MK-A5E065BB32AES1)?
Description
Due to a problem in the MAX® 10 FPGAs' power sequence, the SYSPLL input clock is not stable before the configuration process of the Agilex™ 5 FPGAs. You may observe that the Agilex™ 5 FPGA GTS PCIe AXI Streaming design example fails to operate and enumerate in hardware when loaded from QSPI on the Agilex™ 5 FPGA E-Series 065B Modular Development Kit (MK-A5E065BB32AES1).
Resolution
You may download the updated POF file for MAX® 10 FPGAs (max10-output-file-1-b.pof), follow the steps below to program the MAX® 10 FPGAs POF file with a USB Micro cable:
- Set Switch S13-3 to "OFF" and plug in the USB Micro cable between the Dev Kit and the PC.
- Power on the Dev Kit.
- Open the Command Prompt in Windows, and run below commands:
- jtagconfig --setparam 1 JtagClock 16M
- jtagconfig --setparam 1 JtagClockAutoAdjust 0
- jtagconfig --setparam 1 InternalMaxSelect 1
- Open the Quartus® Programmer GUI and program the MAX® 10 FPGAs POF file.
- Power cycle the Dev Kit.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
