Knowledge Base Article
Why does the generation of the altsyncram IP from the command line fail?
Description
Command line generation of the altsyncram IP component is not supported in the Quartus® II software version 13.0 and later.
The chapter Command Line Scripting (PDF) in the Quartus II Handbook version 13.0 incorrectly indicates that the following command can be used to generate a RAM or ROM IP:
qmegawiz -silent module=altsyncram -f:rom_params.txt myrom.v
Resolution
The documentation is updated in the Quartus II Handbook version 13.1
Updated 11 months ago
Version 3.0
