Knowledge Base Article
Why does the Frame Buffer MegaCore not generate simulation model from Qsys?
Description
In Quartus® II software version 12.1, when trying to “Create Simulation Model” in Qsys for the Frame Buffer MegaCore®, you may receive the following error messages:
Error: Unable to generate simulation model for testFB_alt_vip_vfb_0
Error: Generation stopped, 1 or more modules remaining
Error: ip-generate failed with exit code 1: 8 errors, 0 warning
These error messages indicate that Qsys is unable to generate the simulation model for the Frame Buffer MegaCore and causes the Qsys system generation to fail.
Resolution
This issue is fixed in Quartus II software version 13.0.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
