Knowledge Base Article
Why does the EDA Simulation Library Compiler fail to compile the tenm_hssi_ver and tennm_hssi_f0_ver libraries?
Description
In the Intel® Quartus® Prime Pro Edition Software, you may see that these libraries fail to compile in the EDA Simulation Library Compiler.
This problem occurs when tile-based IPs are generated in Platform Designer.
Resolution
To avoid this problem, map all logical libraries named tennm_hssi_<X>_ver  where <X> could be a two-letter string, such as f0, to logical library tennm_hssi_all_ver.
This mapping can be done using vmap command.
For example, the library compiler compiled the library tennm_hssi_all_ver  into directory /libraries/tennm_hssi_all_ver.
Run command  "vmap tennm_hssi_f1_ver /libraries/tennm_hssi_all_ver"
Updated 11 months ago
Version 3.0
