Knowledge Base Article
Why does the DDR3 Micron MT41J64M16LA memory preset specify the incorrect data width?
Description
When you select the Micron MT41J64M16LA-15E memory preset in the DDR3 ALTMEMPHY based controller, the data width is incorrectly specified as 8 bits by default, but in fact, this device is a 16 bit wide device.
Resolution
You will need to manually change the data width from 8 bits to 16 bits.
This issue is fixed in the Quartus® II software version 12.0.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
