Knowledge Base Article
Why does the Bursting Avalon-MM Master (BAM) interface of the Multi-Channel DMA FPGA IP for PCI Express* write data at an incorrect address in the Quartus® Prime Pro Edition software version 25.1 or earlier?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1 and earlier, the Bursting Avalon Master (BAM) interface of the Multi Channel DMA FPGA IP for PCI Express may output the write data for a Memory Write transfer at an incorrect address when there is device-side backpressure.
Resolution
To work around this problem, download the patch 0.22 for the Quartus® Prime Pro Edition Software version 25.1 below.
This problem has been fixed in version 25.1.1 of the Quartus® Prime Pro Edition software.
Updated 8 months ago
Version 4.0
