Knowledge Base Article
Why does the address range of my Qsys PIO, Interval timer and Jtag Uart change when I add a new Avalon-MM master?
Description
An issue has been identified where the address range of some Altera® slave peripherals is dependant on the data-width of the largest Avalon®-MM master in the project.
The following IP's may be effected:
- DMA Controller
- Remote Update Controller
- Alpha Blending Mixer
- Control Synchronizer
- Switch
- Clocked Audio Input
- Clocked Audio Output
- SPI (3 wire serial)
- UART
- JTAG Uart
- Mutex
- Performance Counter Unit
- Character LCD
- Interval Timer
- PIO (Parallel I/O)
- USB Data Streamer Controller
Resolution
This issue may be fixed in a future version of the Quartus® II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
