Knowledge Base Article
Why does the 1G/2.5G/5G/10G Multi-rate Ethernet PHY IP Core fail to establish the link in 1G or 2.5G speed mode?
Description
Due to a problem in the 1G/2.5G/5G/10G Multi-rate Ethernet PHY IP Core version 15.1 and 16.0, the PHY RX may get stuck in a failure state and fail to establish the link when contiguous special code-groups (/K28.1/, /K28.5/, and /K28.7/) are received. The PHY RX outputs gmii16b_rx_d[15:0]=0x0E0E, gmii16b_rx_dv[1:0]=0x0, and gmii16b_rx_err[1:0]=0x3 if the PHY IP is stuck in the failure condition.Resolution
To work around the problem, reset the PHY IP Core through the control register bit[15] RESET or restart auto-negotiation through the control register bit[9] RESTART_AUTO_NEGOTIATION. This problem is scheduled to be fixed in a future release of the Quartus® Prime Software.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
