Knowledge Base Article
Why does simulation of the altera_syncram IP fail when memory initialization is enabled for Agilex® 27 FPGA and SoC devices?
Description
Due to an issue in the Quartus® Prime Pro Edition software version 26.3, simulation of the altera_syncram IP with memory initialization enabled may fail for designs targeting Agilex® 27 FPGA and SoC devices. This issue also affects the On-Chip Memory II IP.
The issue occurs in Questa*–Altera® FPGA Edition because the default simulation optimization may optimize away the memory initialization file, preventing the memory from being initialized as expected.
Resolution
To work around this issue in the Quartus® Prime Pro Edition software version 26.3, apply the -voptargs=+acc flag when simulating a memory-initialized altera_syncram in Agilex 27.
This flag preserves access to internal simulation objects that might otherwise be optimized.
This issue is currently scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.
