Knowledge Base Article
Why does Run As Nios II ModelSim fail to launch ModelSim software ?
Description
In Quartus® II v10.1, when you try to run an application with Run As Nios® II ModelSim® in Nios II Software Build Tools for Eclipse, you will see the following error message: "No such file or directory".
A patch is available to fix this problem for the Quartus II software version 10.1. Download and install the appropriate patch and readme file from the links below:
- Quartus II software version 10.1 patch 0.18 for PC (.exe file)
- Quartus II software version 10.1 patch 0.18 for Linux (.tar file)
This issue is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
