Knowledge Base Article
Why does Qsys fail to generate a .bsf?
Description
Due to a problem in the Quartus® II software versions 12.1 and earlier, Qsys may fail to generate a Block Symbol File (.bsf) even if the option to create a .bsf is turned on. This problem can occur when you have spaces in your path.
Resolution
To work around this problem, ensure that your path does not include spaces.
Updated 11 months ago
Version 3.0
