Knowledge Base Article
Why does programming a configuration device with Cyclone® IV E EP4CE75 devices fail when a jtag indirect configuration (.jic) file is used?
Description
Due to a problem with the factory default Serial Flash Loader (SFL) in the Programmer tool of the Intel® Quartus® Prime Software, programming a configuration device with Cyclone® IV E EP4CE75 device may fail when a jtag indirect configuration (.jic) file is used. This problem affects the following versions of the Intel® Quartus® Prime Software:
  • Intel® Quartus® Prime Standard Edition Software v20.1.1 and earlier
  • Intel® Quartus® Prime Pro Edition Software v21.2 and earlier
Resolution
Use the Programmer tool of the following version of the Intel® Quartus® Prime Software:
  • Intel® Quartus® Prime Standard Edition Software v21.1 and later
  • Intel® Quartus® Prime Pro Edition Software v21.3 and later
Related Articles
How can I constrain the timing of the Serial Flash Loader (SFL) IP in Cyclone® III and Cyclone® IV devices?
Updated 11 months ago
Version 3.0
