Knowledge Base Article
Why does Platform Designer testbench generation fail with Blackbox IRQ?
Description
Due to a problem with the Quartus® Prime Pro Edition Software version 24.2 and earlier, you might see the process fail when you generate a testbench system from the Platform Designer Tool. This problem occurs when the Platform Designer system includes a black box component with an exported IRQ interface.
Resolution
To work around this problem, add an interrupt bridge to the IRQ interface.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 5 months ago
Version 4.0
