Knowledge Base Article
Why does PCIe® core return multiple unexpected completion data in response to the host's memory read request on Avalon-MM interface?
Description
This issue may be caused by mismatches between PCIe®  clock configuration and system clock connections in SOPC builder.
When "Use PCIe core clock" field is selected in "Avalon® Clock Domain" under "Avalon" tab, the core expects application clock is the same as pcie_core_clk. So, if the user logic uses different clock source, the core may return multiple garbage data.  In this case, you may see many assertions of TxsReadDataValid_o and TxsReadData_o on Avalon-MM interface with or without pending MRD requests.
There are two ways to fix this issue:
1. If synchronous design is intended, select 'Use PCIe core clock" and connect pcie_core_clk to the rest of the application clocks.
2. If asynchronous design is desired, pick "Use Separate clock" and application clock can be connected to any clock source.
Updated 2 months ago
Version 2.0
