Knowledge Base Article
Why does my simple dual-port memory not function correctly in RTL simulation?
Description
Due to a problem in the Quartus® II software version 11.1 and later, the altsyncram simulation model incorrectly delays the output data by one extra clock cycle when reading from a simple dual-port memory implemented using MLAB resources. This issue occurs when the read-during-write option is set to Old data.
Resolution
A patch is available to fix this problem in the Quartus II software version 11.1 SP2. Download and install patch 2.32 from the appropriate link below:
This problem is fixed beginning with the Quartus II software version 12.0 SP1.
Updated 4 months ago
Version 4.0
