Knowledge Base Article
Why does my Nios® II Simple Socket Server design example fail to auto-negotiate at 1G speed?
Description
Due to the default timeout period in the Simple Socket Server template, there is a possibility that auto-negotiation at 1G speed may fail in Cyclone® V, Cyclone® 10, and Max® 10 devices.
Resolution
To work around this problem, the user is required to modify the BSP source code to increase auto-negotiation timeout delay and recompile to generate the new ELF file using the instructions below.
Open the following file in the project directory:
../software/<project_name_bsp>/drivers/src/altera_avalon_tse.c
Change the timeout delay from "usleep(1000)"  to "usleep(5000)" as shown in the next portion of code:
alt_32 alt_tse_phy_restart_an(alt_tse_phy_info *pphy, alt_u32 timeout_threshold) {
while(alt_tse_phy_rd_mdio_reg(pphy, TSE_PHY_MDIO_STATUS, TSE_PHY_MDIO_STATUS_AN_COMPLETE, 1) == 0 ){
if(timeout >  timeout_threshold) { tse_dprintf(4, "WARNING : PHY[%d.%d] - Auto-Negotiation FAILED\n", mac_group_index, mac_info_index);
/* Restore previous MDIO address */
alt_tse_phy_wr_mdio_addr(pphy, mdioadd_prev);
return TSE_PHY_AN_NOT_COMPLETE;
usleep(5000); //updated from usleep(1000)
Updated 11 months ago
Version 3.0
