Knowledge Base Article
Why does my HDMI Example Design IOPLL fail to lock on Intel® Arria® 10 and Intel Cyclone® 10 GX devices when generated using Intel Quartus® Prime versions 18.1.1 and earlier?
Description
Due to a bug in the HDMI Example Design generated with Intel Quartus Prime versions 18.1.1 and earlier, the IOPLL may fail to lock for incoming TMDS clock frequencies between 171Mhz and 340MHz on Intel Arria 10 and Cyclone 10 GX devices.
Resolution
To fix this problem you can open the following files and edit them as shown below.
\hdmi_0_example_design\rtl\reconfig_mgmt\mr_rom_pll_valuemask_8bpc.v
\hdmi_0_example_design\rtl\reconfig_mgmt\mr_rom_pll_valuemask_10bpc.v
\hdmi_0_example_design\rtl\reconfig_mgmt\mr_rom_pll_valuemask_12bpc.v
\hdmi_0_example_design\rtl\reconfig_mgmt\mr_rom_pll_valuemask_16bpc.v
Change from this
// ROM OFFSET 4 (171MHz - 340MHz)
ROM[33] <= 32'h00000010; // cp
ROM[34] <= 32'h000000C0; // bw
To this
ROM[33] <= 32'h0000000B; // cp
ROM[34] <= 32'h00000080; // bw
\hdmi_0_example_design\software\tx_control\xcvr_gpll_rcfg.c
Change from this
case 4: // <340MHz
else
GPLL_RCFG_WRITE(0xC2, 0x00000808); // c2 16
GPLL_RCFG_WRITE(0x20, 0x00000010);                            // cp
GPLL_RCFG_WRITE(0x40, 0x000000C0);                            // bw
To this
case 4: // <340MHz
else
GPLL_RCFG_WRITE(0x20, 0x0000000B);                            // cp
GPLL_RCFG_WRITE(0x40, 0x00000080);                            // bw
This problem will be fixed in a future version of the Intel Quartus Prime generated Arria 10 and Cyclone 10 GX HDMI Example Designs.
Updated 3 months ago
Version 2.0
