Knowledge Base Article
Why does MATLAB crash when I open DSP Builder?
Description
When I open DSP Builder from the start menu, MATLAB crashes. MATLAB opens fine as standalone software.
Resolution
To work around this problem, separately launch MATLAB and set-up paths:
  • In the dspba installation directory, edit dsp_builder.bat to remove the command "run(\'%DSPBA_ROOT%\setup_dspba.m\');" Then each time you open MATLAB from the shortcut, manually run setup_dspba.m after opening from the command line.
  • Permanently save the file path to include the DSP Builder-added paths
  • Ignore the shortcut, open MATLAB independently and run the commands the dsp_builder.bat file executes:
    setenv(\'DSPBA_ROOT\',\'C:\altera\13.1\quartus\dspba\')
setenv(\'DSP_BUILDER_ROOT\',\'C:\altera\13.1\acds\quartus\dsp_builder\')
setup_dsp_builder
Updated 11 months ago
Version 3.0
