Knowledge Base Article
Why does area estimation may present difference between text output and report.html with FPGA OpenCL™ SDK?
Description
When you compile the OpenCL™ design with FPGA OpenCL™, you may get different area estimations between text output and report.html. Such as listed below:
Type |
resource usage (ALUTs) |
Text ouput Report.html |
26% 24% |
Resolution
This is because that after FPGA SDK for OpenCL™ version 17.1, the text output is outdated is no longer maintained, and there's a warning message to guide the user to use one the report.html as "The report below may be inaccurate. A more comprehensive resource usage report can be found at /reports/report.html".
Updated 11 months ago
Version 4.0No CommentsBe the first to comment
