Knowledge Base Article
Why do the write, sector_erase or bulk_erase operations of ALTASMI_PARALLEL perform incorrectly?
Description
Due to a problem in Quartus® II software versions 13.0 and 13.0sp1, the ALTASMI_PARALLEL doesn't conduct the correct sequence when the write, sector_erase or bulk_erase operations are executed after read_rdid or read_status operations.
Resolution
If you do not execute the read_rdid or read_status operations immediately before the write, sector_erase or bulk_erase, these will function as expected.
This problem is resolved in the Quartus II software version 13.1.
Updated 10 months ago
