Knowledge Base Article
Why do the EMIF sub-IPs have incorrect parameters after applying a preset in the Memory Subsystem FPGA IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3, the parameters of EMIF sub-IPs might not be set correctly after applying a preset in the Memory Subsystem FPGA IP.
Resolution
Do not use any preset. Configure your memory subsystem manually.
This problem has been fixed in the Quartus® Prime Pro Edition Software version 23.4.
Updated 11 months ago
Version 3.0
