Knowledge Base Article
Why do Remote System Update (RSU) use cases fail in Agilex® 3 FPGA device in QPDS26.1.1_REL_GSRD_PR release?
Description
Due to a problem in QPDS26.1.1_REL_GSRD_PR release, most of the Remote System Update (RSU) use cases are not functional in Agilex® 3 FPGA, when these are exercised from U-Boot. One of the issues observed is the scenario in which the rsu update command is called to load an application from a valid slot address; the error is shown next:
SOCFPGA # rsu update 0x00600000
RSU: RSU update to 0x0000000000600000
RSU: mbox_rsu_update failed (1023)
On Linux, most RSU functionality works correctly, but the rsu_client --log command reports an incorrect STATE after a WDT expiration event.
./rsu_client --log
VERSION: 0x0ACF0202
STATE: 0xF0060001 ← Linux should report 0xf0060002. The 0xF0060001 value is normally reported by U-Boot.
CURRENT IMAGE: 0x0000000000800000
FAIL IMAGE: 0x0000000000800000
ERROR LOC: 0x00000000
ERROR DETAILS: 0x00000000
RETRY COUNTER: 0x00000001
Resolution
To workaround for this problem you can use the Quartus design (.sof) from QPDS26.1_REL_GSRD_PR release. You can also use all the components (.sof, hps software and DCMF ) from QPDS26.1_REL_GSRD_PR release. This problem will be fixed in a future release.
Updated 15 hours ago
