Knowledge Base Article
Why do my IP core scripts fail to work?
Description
In the Quartus® II software version 14.0, you see one type of wizard when you are edit or upgrade an old IP core instance and you see a different wizard when you create a new IP core instance. In addition, the output files and directory structure depends on which wizard generates the IP core, which may affect any output scripts you define. This problem affects the following IP cores
- Altera Fault Injection
- FIR Compiler II
- RapidIO
- Reed Solomon II
Resolution
To work around this problem, update any scripts you have that work on IP cores in v13.1 designs.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
