Knowledge Base Article
Why do I see the following message when attempting to start Transceiver Toolkit (TTK) in Quartus Prime software version 16.0? com.altera.debug.core SEVERE: TTK failed reading from PHY slave_<slave address>
Description
Due to a problem in the Quartus® Prime version 16.0 software, you may see any of the messages below when you start Transceiver ToolKit (TTK) for a non-PCIe® interface but have a PCIe interface in your design. You may also see these messages when you start TTK for a PCIe interface.
You may also see errors in the System Console tree as shown in this screenshot .
This is due to missing clock connections for the Hard IP for PCI Express® IP core's Transceiver Reconfiguration Controller, which impacts the use of TTK for other interfaces.
SEVERE: TTK failed reading from PHY slave_, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset.
SEVERE: open_service: Could not open service at /devices/)|..@1#USB-1#<....>/master: Channel busy
error: open_service: Could not open service at /devices/)|..@1#USB-1#<...>/master: Channel busy
    while executing
"open_service master $"
    (procedure "" line 6)
    invoked from within
    (file "" line )
    invoked from within
Resolution
To work around this issue, edit the instantiation of the Hard IP for PCI Express® core and add the PCIe reference clock to the Transceiver Reconfiguration Controller connections as shown below. Replace <refclk_clk> below with the actual PCIe refclk signal used in your design.
.xcvr_reconfig_clk              (1'b0),
.reconfig_pll0_clk              (1'b0),
.reconfig_pll1_clk              (1'b0),
TO:
.xcvr_reconfig_clk              (<refclk_clk>),
.reconfig_pll0_clk              (<refclk_clk>),
.reconfig_pll1_clk              (<refclk_clk>),
This problem is scheduled to be fixed in a future version of the Quartus® Prime software.
Related Articles
Updated 4 months ago
Version 4.0
