Knowledge Base Article
Why do I see Memory Write CAS Latency (CWL) of 5 in my simulation when I set this parameter to be 6 in the DDR3 High Performance (HP) Controller IP Megawizard?
Description
If you have set up your DDR3 HP Controller IP Megawizard® "Auto-Calibration Simulation Options" in "Skip Calibration" mode, in the simulation you will see the CWL of 5 even if you have set the CWL parameter to 6 in the IP Megawizard.
The Quartus® II software and IP version 8.1 and earlier only support CWL of 5 for "Skip Calibration" mode.
Change the setting for "Auto-Calibration Simulation Options" to "Quick Calibration" or "Full Calibration" mode to get correct CWL value of 6 in the simulation.
This issue will be fixed in the future version of the IP and Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
