Knowledge Base Article
Why do I see JTAG problems when using the SignalTap II Logic Analyzer with the Quartus Prime Pro edition Sotware?
Description
In the Quartus® Prime Pro edition software, the JTAG signals are no longer automatically constrained by the software.
As a result of this you may experience triggering problems using the SignalTap™ II Logic Analyzer and any other tools using the JTAG interface.
Resolution
Apply timing assignments, such as the examples below, to ensure correct functionality of the JTAG interface:
set tck_freq 10MHz
set tdi_input_delay_min 2
set tdi_input_delay_max 3
set tms_input_delay_min 2
set tms_input_delay_max 3
set tdo_output_delay_min 3
set tdo_output_delay_max 4
create_clock -name altera_reserved_tck -period [get_ports altera_reserved_tck]
#cut all paths to and from altera_reserved_tck
set_clock_groups -asynchronous -group [get_clocks altera_reserved_tck]
# I/O min delays
set_input_delay -clock altera_reserved_tck -clock_fall [get_ports altera_reserved_tdi] -min
set_input_delay -clock altera_reserved_tck -clock_fall [get_ports altera_reserved_tms] -min
set_output_delay -clock altera_reserved_tck [get_ports altera_reserved_tdo] -min
# I/O max delays
set_input_delay -clock altera_reserved_tck -clock_fall [get_ports altera_reserved_tdi] -max
set_input_delay -clock altera_reserved_tck -clock_fall [get_ports altera_reserved_tms] -max
set_output_delay -clock altera_reserved_tck [get_ports altera_reserved_tdo] -max
Note that the values for tdi_input_delay_*, tms_input_delay_* & tdo_output_delay_* should match the destination hardware.
Updated 11 months ago
Version 3.0
