Knowledge Base Article
Why do I see a Qsys width mismatch error when I connect pll_locked to transceiver reset controller?
Description
Due to a problem in the Quartus® II software version 14.0 and later, Qsys generates this error when you connect pll_locked to transceiver reset controller. This error affects designs that contain the JESD204B IP core. The width of pll_locked from the IP core is based per channel not per PLL.
Resolution
To work around this problem, create an adapter component with the following parameters to enable the connection in Qsys:
* Adapter input pll_locked_from_jesd[1:0]
* Adapter output pll_locked_from_jesd[1:0] with an output width of pll_locked_to_xcvr_rst_ctrl
Updated 11 months ago
Version 3.0
